2020-08-17 02:43 AM
2020-08-26 06:05 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-26 09:07 AM
2020-08-27 04:40 AM
Minh Nguyen
GRAPHISOFT
2020-08-27 04:57 AM
mnguyen wrote:Well, it is still a bit a mystery ... so I did a test.
Unfortunately no. If we place a survey point in the hotlink module, it will still be exported to IFC through the host file. If a survey point exists in the plan, it will be the origin of the IFC model no matter what.
I hope my explanation is clear enough. Please let me know if you have any further questions!
2020-08-27 05:17 AM
Minh Nguyen
GRAPHISOFT
2020-08-27 05:59 AM
Minh Nguyen
GRAPHISOFT
2020-08-27 10:09 AM
mnguyen wrote:Thank you for clarifying that. It is good like it is.
It is true that Survey point is neglected if it is placed in the hotlink module. With this way we can make sure that incoming hotlinks will not modify the position of our model unintentionally.
2020-08-28 07:08 AM
Minh Nguyen
GRAPHISOFT
2020-08-28 09:29 AM
mnguyen wrote:I spent already a notable time on researching and experimenting and I could not find that much on it either in the documentation.
I tried to look for any written material on what the difference is between IFC Global Origin and IFC Site Location when you hotlink an IFC file, but nothing useful comes up so far.
mnguyen wrote:No, definitely not. It is set to zero for sure and I tried it out multiple times in and with multiple files. Always the same result.
I'm wondering during hotlinking, is there any Additional Offset set? From my experience, this should affect the Z value in Survey point in hotlink module.
2020-08-28 09:34 AM
2020-08-31 02:53 AM
Minh Nguyen
GRAPHISOFT
2020-08-31 04:27 AM
mnguyen wrote:Hi, I sent you the file via a private message. Thx.
As always, if you need a secure address to upload your file, please let me know!
2020-09-13 10:15 PM
Minh Nguyen
GRAPHISOFT
2020-09-28 03:00 AM
mnguyen wrote:So to be precise and sum it up you mean it does not consider the Z-Position when hotlinking and this is the usual behaviour? When you write (yet) in brackets does this mean that this is going to be changed in the future?
Whenever we use 'hotlink' to import an IFC, it doesn't consider the position of the survey point (yet).
2020-09-28 03:54 AM
Minh Nguyen
GRAPHISOFT
