Surfaces won't delete.
Viktorhgo
Hi All,
I'm working on a new template for my office, and I'm working on deleting and updating the surfaces on the template. However, I noticed the file has a lot of surfaces we don't use. And After deleting the surfaces when I open the file again, the file has all the surfaces I just deleted.
Any tips you could help me with?
Certain library objects can create surface attributes.
No matter how many times you delete them they will re-appear when you re-load the library.
Usually you can tell these attributes come from library parts as they will appear with italic text or maybe an underline in the attribute manager.
Tracking down the library part is another matter.
6 REPLIES 6
did you remove the unwanted surfaces using the Attributes Manager, Surfaces Menu, Library Manager, or by deleting a .lfc file ?
Guru
Might said surfaces be part of some loaded object?
Win10 | R5 2600 | 16GB | GTX1660
I Deleted and clean the library manager and the problem was solved.
Thanks.
Do you know how I can track these objects and make them not create new surfaces?
It could be in the Embedded Library or any other library you have loaded, you might find a 'Master_GDL.....' object.
It may be called something obvious like 'Master_GDL_materials' or it may be something more obscure - but it will still have "Master_GDL' in the name.
If you open the GDL object you will see it defining the materials/surfaces.
Remove it from your library and it will no longer create those materials.
However your existing jobs will still have them because they would have already been created - you will have to delete them.
It is possible for any object to define a material, fill, line-type, but as far as I know, these will only be available for that object and not in the entire job as an attribute.
So these should not be a problem.
