Too many different volume results form the same element.
Can ArchiCAD actually produce a reliable schedule for volume?
For example, a simple foundation plan where you need to schedule the volume of the footings and stem walls.
I am not sure how ArchiCAD is making the calculations but they are not giving me the results I need.
The label with show one size, the schedule another, and dimensions even different from that-- and all for the same thing. Volumes calculated for the same thing are different if you model the footings as one monolithic slab or if they are modeled as walls.
Any tips on how to manage this for consistent and reliable results?
Model walls/footings with centerline reference lines only? Model footings/walls as Trapezoids so you can miter the corners so the intersects will not be calculated twice?
How is ArchiCAD making the volume calculation? If two footings/walls are connected at a 90 deg. corner, do they show as one volume but separate them and they show a different total volume?
I need to know how ArchiCAD is making this kind of calculation so I can find some modeling and dimensioning solution that will match/generate accurate schedules for volume.
What will generate the most accurate result? Making the calculations by hand I would use the dimension/length of the footing at the centerline of the footing. ArchiCAD is basing its calculation on how it intersects at the corners. But I don't know what the priority is for how it makes the connections. I can see it by selecting a footing/wall but not every cleanup/intersection is predictable with angled walls.
In any case, the ArchiCAD schedules I am using are not accurate and if they are consistent I am not able to predict it.
7 REPLIES 7
... and the results for total volumes reported in the in the schedules are wrong.
If you have ever checked your foundation schedules against your hand calculations you will know what I mean.
There must be some careful coordination between the parameters being used in the schedules and the reference lines of the walls to generate a useable and reliable schedule. I don't know exactly what that is yet but I do know that my schedules are not accurate.
If you zoom in on this picture you can see the green lines that show how ArchiCAD has cleaned up the wall intersects in a way that does not produce consistent reporting of the wall lengths. They are accurate I am sure, but not generating a useful result.
3/4 of a cubic yard difference in the true volume and the volume of the schedule for just this one type of footings. The schedule is made from the footings which were modeled as walls. The true volume is computed by hand, modeled as slabs, and as one slab.
Scheduling the footings/walls does not generate an accurate volume, the lengths shown in the labels are not the same as the lengths shown in the schedules, which are not the same as the dimensions, and it is doubtful if you can even model continuous footings as walls and expect an accurate result for volume in the schedule.
I am going to check and see it there is some way to do it accurately by moving reference lines to the center of the wall or something but I am skeptical that there will be any good solution.
The Schedules we can make in ArchiCAD always take some kind of work-around to make them work the way I want it to work.
To show the difference between volume of the schedules, true and accurate volume, I converted the foundation walls and footings into an object, then converted that into a morph - then scheduled the volume of the morph.
This morph volume should be the true volume of all the footings and foundation walls. But of course it does not add up to the same volume of the other schedules.
David Bearss
Thought I was getting odd results to so did a simple experiment. Walls are 1 foot tall and do not intersect as this is how one would calculate by hand. What it shows is the ends ore not calculated as outside face. BTW the reference line is the outside face.
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
David Bearss
Then I joined all the walls. Volume is the same but outside face and length of outside face increase as now the exposed ends of the walls are gone.
David Bearss
Alienware 17 R5
David Bearss
Then the surprise; changing one wall to have reference line at center increases the outside face, length of wall on outside face and the gross volume of the wall. Not sure where this leads next but to me it all has to do with the placement of the reference line.
David Bearss
Alienware 17 R5
Zoltan Fuchs
@David Bearss
Yes it changed, because the geometry has changed.
When you change the reference line the wall moved with half of wall thickness. Compare images what you attached.
i7-4770K / 16GB / GTX560 2GB / 512GB SSD / Win10 64bit
AC21 (HUN-64 bit) / Bimx Pro / Revit 2017
