Collaborate forum
Forum Posts
Multiple Criteria in the Interactive Scheduler
Is this possible yet? Has anyone found a way around it? I have posts and beams in my drawings and I am trying to pull a list of them. So my criteria are: be an object named post or named beam be on post layers or be on beams layer But the scheduler d...
Anonymous by Not applicable
  • 11974 Views
  • 11 replies
  • 0 likes
Library location
I'm about to start putting together a custom library to be used alongside the standard archicad 9 library in my office (of 7 Archicad users). Can this new library live on our server, or is it better (in terms of loading speeds + data protection) to h...
  • 7367 Views
  • 5 replies
  • 0 likes
Can't export dwg files from AC9 since update
Hello, Since i've updated AC9 to build 2219, i can't export any dwg or dxf files anymore. I even tried publishing, saving, and via Plotmaker, nothing works. Even tried to adjust translation settings... no solution... don't know what to do next... I a...
  • 3136 Views
  • 5 replies
  • 0 likes
DWG model space as one block
why is it that when I publish DWGs from PM the model space information in AutoCAD are shown as a single Block and they must be exploded before someone can edit them in AutoCAD.(my setting are attached) If I use the "linked xref document" option then ...
  • 3627 Views
  • 5 replies
  • 0 likes
Conversion to 10
I've spent alot of time creating various things specific to the types of projects we do including: Wall composite types Library parts Fills Materials Interactive Schedules Pens sets for various drawing types (plans elevations) Will these have to be r...
  • 23011 Views
  • 23 replies
  • 0 likes
PDF with AC 10
It is little bit too early to ask: Can we work on PDF-file in AC10? In the past time I had to do the followings: First open the PDF with Adobe Illustrator, and than save as DWG, and than exprot to PM, and from PM save as DXF, and open this file with ...
  • 3045 Views
  • 5 replies
  • 0 likes
Elusive "Door Panel"
I'm trying to create a IS door schedule, and would like to use the "Door Panel" parameter (the one that lists "Flush", "Standard 4 Panel", etc), but can't seem to be able to get it into the schedule. I ended up bringing ALL the parameters into the sc...
  • 5999 Views
  • 5 replies
  • 0 likes
