Teamwork & BIMcloud
out-of-date section element ?
I'm using archicad 14 tw2. Working on a wall section then when i hover over any element in the drawing it says "Out-of-date section element".
I've tried reloading the project, send/recieve, release all, rebuild from model....nothing works. How do i get the elements in this section to update?
...gonna try rebooting
4 REPLIES 4
rebooting worked šŸ™‚
When you chose Rebuild from Model, did you reserve the Section first?
It should work that way and there should be no need for reboot.
No the section wasn't reserved, ill try that next time.
Was fixing some walls through sections and one of them said "out of date" so read this port and the part of rebuilding the model and the all of the sudden, some of the dimensions and fills/lines where moved. Any idea why this happens?
I restarted my mac and nothing changed in plans or 3D model.
