David Collins
25% Solid Fills in AutoCAD?
I'm converting a set of PLN docs to DWG and I'm having problems with the 10% and 25% solid fills I use for some materials and shadows in the elevations. (Carried over from the days of zipatone)
In the DWG format these translate as solid foreground fills in seemingly random colors. Are these kinds of fills not supported in AutoCAD? Or is there a setting in the translator that I'm missing?
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
8 Replies 8
David Collins
Okay, AutoCAD seems to think we're all still using pen plotters, so those partial screen patterns don't work. I'll work with vectoral hatch patterns, ie Rapidograph instead of Zipatone. Been there & done that, too.
David Collins
Red
I am having the same problem as you (I think), but can not find a easy solution to get the same look. I normally use 75% fill to cover certain areas on a section or elevations to give extra depth past "Marked Distance Area". However once it is exported to DWG, the fills (now hatch) become solid. Hopefully I am overlooking a simple solution.
What vectorial fill are you using?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
DGSketcher
Legend
Same problem here and carrying out a hatch redefinition exercise in LT is a pain
Erwin Edel
Not entirely sure, but I think that AutoCAD did not have transparancy options for fills until 2012 or so. Check that you are exporting to one of the newer DWG formats, maybe.
We use a diagonal vectorial line fill for shadows with a grey pen with a fairly thin pen weight. This exports fine to DWG, as far as I know.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Red
Unfortunately, I am exporting to 2013 and opening in AutoCAD Architecture 2016. So that doesn't appear to be the problem. However, it could still be a simple setting in the translator that I am overlooking.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Erwin Edel
If you have AutoCAD, you can make a template file with the type of fills you want to translate to and setup ArchiCAD to convert the percentage fills to those fills.
http://helpcenter.graphisoft.com/guides/archicad-19/archicad-19-int-reference-guide/user-interface-r...
www.leloup.nl
Eduardo Rolon
and if you don't have AutoCAD you can use Draftsight to create the template
http://www.3ds.com/products-services/draftsight-cad-software/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Red
I noticed that after posting my last reply. I need to put some time into this.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
