Add new categories to zones and materials
I'm new to scheduling although I have been using the rest of AC for some time.
I am wanting to use the Scheduler in 2 different ways but I think the process of doing it is the same!
Firstly at an urban level to use zones to show a population number and a density, AC knows the area so can I add a total population parameter to a Zone stamp? Secondly, can AC divide one by the other to give a density??
At a building level, I want to be able to calculate the embodied carbon in the materials. AC knows the volume of each material, I want to add density and carbon per KG to the materials, then get AC to multiply this up.
Any assistance would be gratefully recieved.
Regards
Matt
10 REPLIES 10
Ofcourse, it can be programmed. I did see the LGZone, but I decided not to bring it into the Total Zone, because I don't have the expertise. contact me and I will see what I can do.
Also the brilliant Zonematic add-on can have a custom zonestamp like mine. The Zonematic add-on works even with a custom zonestamp if you put the right parameters in it. I'll be happy to integrate it.
