‎2021-08-10 06:47 AM
‎2021-08-10 07:16 AM
‎2021-08-11 02:53 AM
Barry wrote:
Are you changing renovation filters?
Maybe this will help explain.
https://archicad-talk.graphisoft.com/viewtopic.php?f=26&t=62958&p=330591&hilit=annotation#p330591
‎2021-08-11 09:51 AM
This deletion can happen, for example, when you change the Renovation Filter, which influences/changes which elements will/will not be generated in a Schedule.
‎2021-08-13 07:43 AM
LaszloNagy wrote:Oh.. right.. ok thanks.
So, I think, changing the Renovation Filter is just one example that can cause this behavior. I believe there can be other cases. The developers did not tell me all those scenarios.
‎2021-08-13 03:05 PM
‎2021-08-27 09:16 AM
Yvonne wrote:
Why do annotations (in plan/elevation views) disappear from schedules?
I have had this happen in a few different files.. sometimes the additional dimensions disappear and sometimes the notes.
How can I prevent this from happening again?
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2022-07-12 08:00 AM
Hi Minh,
Does this work for teamwork files?
‎2022-07-12 08:10 AM
The registry or plist changes would need to be made on every machine used in teamwork.
It is an operating system change and not one saved in the Archicad file.
‎2023-03-28 11:38 AM
Hi Minh,
Has this been solved? We're on 23 and annotations in schedules behave badly from time to time. The challenge is not to balance data/performance btw. Data needs to be correct, the it should be optimized performance wise.
M
