2021-08-10 06:47 AM
2021-08-10 07:16 AM
2021-08-11 02:53 AM
Barry wrote:
Are you changing renovation filters?
Maybe this will help explain.
https://archicad-talk.graphisoft.com/viewtopic.php?f=26&t=62958&p=330591&hilit=annotation#p330591
2021-08-11 09:51 AM
This deletion can happen, for example, when you change the Renovation Filter, which influences/changes which elements will/will not be generated in a Schedule.
2021-08-13 07:43 AM
LaszloNagy wrote:Oh.. right.. ok thanks.
So, I think, changing the Renovation Filter is just one example that can cause this behavior. I believe there can be other cases. The developers did not tell me all those scenarios.
2021-08-13 03:05 PM
2021-08-27 09:16 AM
Yvonne wrote:
Why do annotations (in plan/elevation views) disappear from schedules?
I have had this happen in a few different files.. sometimes the additional dimensions disappear and sometimes the notes.
How can I prevent this from happening again?
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-07-12 08:00 AM
Hi Minh,
Does this work for teamwork files?
2022-07-12 08:10 AM
The registry or plist changes would need to be made on every machine used in teamwork.
It is an operating system change and not one saved in the Archicad file.
2023-03-28 11:38 AM
Hi Minh,
Has this been solved? We're on 23 and annotations in schedules behave badly from time to time. The challenge is not to balance data/performance btw. Data needs to be correct, the it should be optimized performance wise.
M
