ArchiCAD Nodes showing in DWG export
Hi, I'm working on exporting ArchiCAD drawings into DWGs for consultant use. However, nodes from ArchiCAD are attached to every element in the DWG. I have circled a few of them in the attached image.
I have tried two different methods of exporting:
1) Publish the DWGs using the DWG for Dummies translator and assigning the A-MCUT to the cut layers. Hoping this would isolate all the nodes to one layer which would make it easy to delete them in AutoCAD.
2) Publish a cleaned up worksheet drawing. Still the nodes appear in AutoCAD.
Is there a way to export DWGs without the ArchiCAD object node points?
0 Replies 0
