ā2019-06-25 03:38 PM
Solved! Go to Solution.
ā2019-06-27 07:42 PM
papsphilip wrote:The detail use of this extension is describe in ArchiCad Reference Guide in the Supplement part.
Bruno wrote:Thank you for the reply! It would be really helpful if you could explain a bit more how can i produce this area analysis drawing with the corresponding calculations in Archicad 22? Can you provide a bit more specific instruction because i've been looking everywhere but i cant find it
No it's an ArchiCad Feature for a while, it's an Area List, you'll find it under "Documentation/List Extras/Area List" (see attached Image).
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).
ā2019-06-26 03:03 AM
ā2019-06-26 09:27 AM
ā2019-06-27 09:46 AM
ā2019-06-27 02:36 PM
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).[attachment=0]Liste de surfaces.pdf
ā2019-06-27 05:16 PM
ā2019-06-27 05:23 PM
ā2019-06-27 07:06 PM
vakar wrote:My ArchiCad version is a French one, the "List Areas.apx" works in it. It comes with ArchiCad installation.
"List Areas.apx" there is also in Greece & German vers. and works only on them - not INT .
The same I am looking for !
regards
Vasilis
ā2019-06-27 10:43 PM
LaszloNagy wrote:It is also available in the Austrian version...
I am not very familiar with localization-specific ARCHICAD features, but it seems to me that this may be something that was/is? available in German language versions of ARCHICAD.
If anyone knows, please correct me.
