‎2019-06-25 03:38 PM
Solved! Go to Solution.
‎2019-06-27 07:42 PM
papsphilip wrote:The detail use of this extension is describe in ArchiCad Reference Guide in the Supplement part.
Bruno wrote:Thank you for the reply! It would be really helpful if you could explain a bit more how can i produce this area analysis drawing with the corresponding calculations in Archicad 22? Can you provide a bit more specific instruction because i've been looking everywhere but i cant find it
No it's an ArchiCad Feature for a while, it's an Area List, you'll find it under "Documentation/List Extras/Area List" (see attached Image).
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).
‎2019-06-26 03:03 AM
‎2019-06-26 09:27 AM
‎2019-06-27 09:46 AM
‎2019-06-27 02:36 PM
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).[attachment=0]Liste de surfaces.pdf
‎2019-06-27 05:16 PM
‎2019-06-27 05:23 PM
‎2019-06-27 07:06 PM
vakar wrote:My ArchiCad version is a French one, the "List Areas.apx" works in it. It comes with ArchiCad installation.
"List Areas.apx" there is also in Greece & German vers. and works only on them - not INT .
The same I am looking for !
regards
Vasilis
‎2019-06-27 10:43 PM
LaszloNagy wrote:It is also available in the Austrian version...
I am not very familiar with localization-specific ARCHICAD features, but it seems to me that this may be something that was/is? available in German language versions of ARCHICAD.
If anyone knows, please correct me.
