2010-01-28 09:54 PM
2010-01-28 10:13 PM
2010-01-28 10:15 PM
2010-01-28 10:48 PM
NStocks wrote:It all depends on how much of it you have to do and how much you want to learn to use the tool. If you are just modeling a single house it may be easier to put the frames together out of bits and pieces. You will also learn a lot more about construction methods this way.
Ok, I'll try again... Is the tool worth it in the end or would I be better creating the structure manually ( bearing in mind the windows )
2010-01-28 11:03 PM
Matthew wrote:I see. Well I'm currently looking into how I can make custom windows, but even then I will need to add battens/jacking to the window wouldn't I... I wouldn't think that a window will automatically create these for me.NStocks wrote:It all depends on how much of it you have to do and how much you want to learn to use the tool. If you are just modeling a single house it may be easier to put the frames together out of bits and pieces. You will also learn a lot more about construction methods this way.
To get the most out of the Cadimage tool you really have to have pretty god knowledge of framing methods to get it set up properly and to recognize when it's not right.
2010-01-29 02:02 AM
2010-01-29 11:13 AM
2010-01-29 03:31 PM
2010-01-29 05:24 PM
2011-02-07 05:53 PM
