Steve Jepson
Calculate surface area of a composite wall skin
Is there a setting I can choose for showing the surface area of a composite wall skin on the outside face of it?
12 Replies 12
Steve,
till now I did not found a way to show the Surface for Wall skins in Schedules (Volumes yes).
You can export the schedule in Excel and there ADD a field to calculate the SURFACE from the skins Volume. Save the .xls as .pdf and then import that .pdf schedule in AC as External Drawing.
Final result - .pdf Schedule with Skin Surfaces on Layout:
Steve Jepson
Thanks Andro55
