Case sensitivity in translators/exporters
The DWG translators always write out DWG files with lower case filename extensions (.dwg), but ArchiCAD always references them with uppercase filenames (FILE.DWG). This becomes a problem when using a case-sensitive file server (such as Netatalk on ZFS).
I know this is not actually adhering to the AC system requirements, but has anyone found a way to have translators/exporters always export filenames in upper case?
I think your best bet might be to look for and find a utility program that can batch-convert file names in a folder to upper case.
Then you save the files from ArchiCAD, run the batch convert and done.
I don't know any such particular program but I cannot imagine there is no such program somewhere.
Eduardo Rolon
On Mac there is Name Mangler
http://manytricks.com/namemangler/
and there are utilities that watch folders and perform custom actions so that you could automate the changes.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Thanks for the suggestions! Unfortunately we cannot just uppercase our filenames since we also have to upload these files to external project banks and they are actually case-sensitive.
I will have to create a new ZFS volume with casesensitivity=mixed. This will avoid conflicts with existing files that have different cases while providing compatibility for AC when it asks for an existing file with a different case.
I noticed that AC 18 doesn't mention case-insensitivity in system requirements. Can someone confirm this?
