Composite wall & Take-off
I had a Composite wall shown a 6" masonry block, 1 1/2" air space and 1/2" of gyp. bd. The problem is when I use the List Element Basic under "Thickness/Size" it's read as a 8" wall instead of split the fills/material as assigned. What I'm doing wrong?
2 Replies 2
Djordje
Are the materials defined properly in the assigned Property object?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks for that tip, let me check and after vacations I tell you if works or not.
