Our local subscription library (NL version, thanks Kubus!) allows you to show any expression in zone stamp. You can setup model view specific display options for a single zone.
So for example, I want to re-number zones. I can grab the zone number, convert it to numerical expression, add a value to that and show this custom expression instead of the zone number in a different view.
Useful little trick I could pull off recently. Before we would've had to have two sets of zones for this.
Basic calculation stuff: say you know the kg/mÂł value of your building material, you can calculate the weight of elements. Recently been asked to design a boat suitable as house. Basic rule of Archimede, water of course is 1000 kg/mÂł, so I can calculate displacement of water and get a good estimate of the weight of the model.
So far as I can tell, you can pretty much do what you could do in Excel with formulas and there are some options to convert for numerical to textstring and back.
I suppose if you have some cost per element tables that you use for cost estimation, you could setup a lot of rules for this, however you would still miss out on things that shouldn't be modelled (unless you have time to spare), but should be calculated and things like on site costs (toilets, cranes, etc etc).
@arg617, occupant load per m² is part of NL subscription library, maybe push your reseller to offer more service in this regards. I see quite a few topics crop up about missing library parts / options that baffle me, since we have it available in NL and then when I check the part, it has been supplied by our reseller as part of their subscription library.
Come to think of it, we can also combine text strings in the zone stamps. You would also be able to make a custom property to combine this information as needed in to single strings for schedules / zone stamp usage (provided your zone stamp allows you to show properties).
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
