.DWG TO .GSM
Hi to all!
I got big business and now I need to now how to make dwg file to gsm file.
HELP! HELP! HELP!
kleo
20 REPLIES 20
hi, link.
sorry for post cross. Stupid mistake. anyway, I tried that before and when I open this .gsm file it says "no 3D elements".
i have to solve this! emergency!
thanks for now! let's go!
kleo
Hi Karl
ha ha. yeah.. you are right.
at first, I thougt GOKLEO has his DWG file in Archicad already.
^o^.
Hi!
So, like i promised from yesterday. I'm sending PRiNT SCR to see what hapens when I open dwg - nothing, as you can see file GSM 03.
any ideas?
kleo
Link
I don't know what to tell you Kleo - maybe try it again?
It's quite straightforward, but you may have to play around with the translator settings to have text, fills, & splines to appear correctly.
Not sure if figures, drawings, hotspots, S/E's or cameras are translated though.
Good luck.
Link.
Gorazd
Maybe your objects in autocad are made from solids? In this case, you get blank in ArchiCAD. I think you have to save them in 3DS in autocad, to be able to import in Archicad.
Another way is also possible. Open your DWG in Google Sketchup, save it and then import in ArchiCAD via Sketchup plugin. Hope it helps.
Gorazd Rajh
From AC 6.5 onward, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
hello to all!
I think I found out something that nobody told me:
ArchiCAD can't open DWG file made in AutoCAD later than 2000. So, I think that file in AutoCAD should be saved as in AutoCAD 2000.
And than I will SEE dwg file in ArchiCAD and than I can make it .gsm file.
what do you say?
thank to all.
kleo
Archicad 10 can open AutoCAD 2006 DWG files at least, not sure about 2007.
Eduardo Rolon
Have not tried '07 but in theory it shouldn't since the dwg format changed (as they always do every 3 releases) and anyway R2008 is just around the corner. If you can't open them you can use these free utilities.
www.dwggateway.com/
edrawingsviewer.com/
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
hm.. hm...
i'll try. I have to finish this. Gsm is stronger from day to day.
thanks guys.
kleo
Djordje
Autodesk provides a free conversion utility, TrueDWG Convert. Free download. Converts from 2007 down to R14.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
