DWG after Export changing coordination
Hi, I'm trying hard to understand how to export in DWG with right coordination
After my export and opening DWG I see that my "model" is move much way off.
I tried other units (meter and mm ) but it did't change anything.
1. I attached XREF to original coordination and then I draw my situations.
2. After export I can see that XREF is on right place but my drawings is move so much way off
Skärmavbild 2023-10-04 kl. 14.14.48.jpgSkärmavbild 2023-10-04 kl. 14.14.28.jpg
I checked my setting for translator but I don't see anything suspicious why is doing this
Is there any advice how to fix it ?
AC 7 - 27 SWE
MacBook Pro, M4 Pro
2 Replies 2
* Note It's seem that XREF is export in m (meter) but my suggestinon in mm (millimeter)
Is there way how to synchronize those units ? And have it all in m (meter) and on the same place ?
AC 7 - 27 SWE
MacBook Pro, M4 Pro
You could also try to place a Survey Point and in the DWG Translator's Match File's Origin field, select the with Survey Point option.
