‎2007-05-18 06:41 PM
‎2007-05-24 02:54 PM
mark.leslie wrote:I think that u must, after u export all, opet it and copy in one file that will have all drawings !!!
We are trying to export a dwg from ArchiCAD 10 in a format that will match what our client wants. One of our big problems (there have been many) is that we have a number of layouts for diferent plan views etc & our client wants one dwg with everything in. Whatever we try we still seem to get a separate dwg file for each layout, even if single dwg is selected in the translator.
Is there any way to export multiple layouts from ArchiCAD to the paper space of a single dwg file with the model space present as well?
Since this is how AutoCAD users work how else do Graphisoft expect us to produce drawings?
‎2007-05-24 04:05 PM
‎2007-05-24 05:48 PM
‎2007-05-24 06:08 PM
dcbruns wrote:... and how would this put all the plans, sections, elevations, and details in one file?
It sounds to me like you're trying to export from the Layout Book (paper space). Instead, export from the drawing itself and turn on all the desired layers (or you can set your dwg export preferences to export ALL layers instead of just the visible layers).
If you've drawn everything in one file, you can export everything in one file. If you've drawn in different files, then you'll have to combine them first.
‎2007-05-24 06:54 PM
‎2007-05-24 07:25 PM
‎2007-05-24 07:59 PM
‎2007-05-25 03:48 PM
‎2007-05-25 03:54 PM
mark.leslie wrote:You will have to do it manually.
Ideally we want one dwg from multiple layouts. But I am encouraged that others think that it is not standard practice to have everything on one drawing. However we have to keep clients happy if we want to work.
