Exporting to .skp issue
Hi everybody,
I'm having some problems with exporting from AC to *.skp.
I can export it, but the exported skp file is 0 size. When I open it, you guessed it, there's nothing there.
On the other hand I can export the file in every other extention.
Can anybody help me with that?
4 REPLIES 4
Erwin Edel
Which version of Archicad are you using?
You should be able to save to skp from the 3d perspective view from the most recent versions. You should end up with what is shown in 3d perspective in sketchup (after going through a little wizard that lets you pick what to export).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Pertti Paasky
I have problems, too.
Sometimes works, sometimes usually not. Better save as AC17 and then save as .skp.
I think there's a bug. Hope GS fixes the problem.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Same problem for me.
Hope it gets fixed soon.
Katalin Borszeki
Hi All, please make sure that there is no "special" national character in the path where the file is getting saved, in the user name or in the name of the file! As a workaround try logging in as a guest user (with no special character in the user name), the file will most probably save well!!
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
