In the Property Manager, are the Properties made available to elements with Door/Window Classification?
There is a trick that every Property that is used in the Expression must also be made available to elements with Door/Window Classification. This may actually be the reason why no value is returned in the schedule.
If not, can you show a screenshot of the Scheme Settings Dialog where you define the Criteria and Schedule Fields?
