Expression based properties in door/window schedules
ddori
Hello!
I created expression based properties to create automatic ID-s to my doors/windows. They work fine with autotext and automatic labels, stamps. (as you see on the floor plan)
However, in interactive schedules I can't list them.
Do you know any problems that can cause this? They even don't work with the find and select window 😕
Thanks for your help:
Dora
In the Property Manager, are the Properties made available to elements with Door/Window Classification?
There is a trick that every Property that is used in the Expression must also be made available to elements with Door/Window Classification. This may actually be the reason why no value is returned in the schedule.
If not, can you show a screenshot of the Scheme Settings Dialog where you define the Criteria and Schedule Fields?
ddori
Yes, I paid attention for every Classification of the Properties that are used in the Expressions.
My Scheme Settings Dialog looks like:
