Actually, I think it would be useful if this value was displayed when the Frame Thickness = Wall Thickness checkbox is checked so you
1. have some idea of how thick the Frame will be
2. you can schedule it (without modifying the default library).
I  will forward this to Graphisoft as a wish.
PS.: Be prepared to lose this change if a new Library Update comes out for the version and you install it. Or, the library update may not be able to install at all because the default library was changed. It is a good idea to make a backup copy of the default library LCF before making any changes to any of the gdl objects within it.
