2004-10-11 02:45 PM
2004-10-11 03:15 PM
2004-10-11 10:25 PM
2004-10-12 09:35 AM
2004-10-12 12:31 PM
tprokop wrote:That's a new one on me. It shows what happens when when I don't check to see if what I once knew is still true.
Under the "Settings in Selected Translator" area, select the "Open options" and find the "Import drawing data from" line. Change this line to "Paper space with viewport contents" and the results will open with the paperspace views in Archicad.
2004-12-01 11:36 PM
tprokop wrote:It seems that the translator dialog for version 9 has left out the "Paperspace with viewport contents" option in the "Import drawing data from" line under "Open options" in the "Settings in selected translator" area. Anyone have a thought on how to override this? The only options remaining are "Model space" and "Paper space with empty viewports"!
To open a DWG in paper space, change the settings in the translator.
2004-12-02 10:12 AM
wallcrawler wrote:Short of opening it in 8.1, you do have the "old" API provided, that does have that option.
2004-12-02 06:27 PM
2004-12-03 07:09 AM
wallcrawler wrote:The DWG API has been re-written completely, in order to support 2004/2005 DWG. Only the developers can give you the right answer, but the option is sorely needed.
Thanks, Djordje. I never saw that one. Any thoughts as to why this option was removed, or if it will be replaced?
2004-12-03 11:01 PM
If I do need to open the PaperSpace with viewport contents from 2004/2005, I open it in 2005, save as 2000, open it in 8.1, then ... whatever is needed. Quite time consuming.Not to mention extending a dependency on AutoCAD. And a new version, to boot!
