Tom Krowka
Interactive schedule for labels only
I have a DWG from autocad imported into my PLN. It has lots of restaurant equipment (2D blocks only). I would like to point to each piece of equipment with a letter, then add some text (like the name of the piece, voltage and or plumbing requirement, etc). It would be great if I could then use the schedules to pull that information out, total the number of individual units, and generate a schedule that I could update.
I can't figure out a way to do this with the labels included in AC. Can I even generate a schedule with labels only? Don't want to recreate each piece of equipment....this needs to be quick and dirty otherwise I might as well do it the old fashioned way.....one dumb piece at a time typed into a schedule created with row and columns with lines.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 Replies 4
Eduardo Rolon
Use JMurray's Label http://www.onland.info/archives/2015/07/shape_tag_and_label_jm16.php
With this you can schedule it if you use the label object since that one can be scheduled.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Tom Krowka
Eduardo:
Thanks for the quick reply. That's close, but I need to be able to add text within the label, and have that information show up on the schedule. Perhaps as custom text as in some of the other labels.
That label, with the capacity to add several columns of custom text, is what I'm looking for. I need to add things such as the name of the equipment, voltage, etc. that don't show up on the label in the drawing. Or did I miss something with your label?
Tom .
Thomas@wkarchwk.com
www.walshkrowka.com
Dave Seabury
Tom
With the shape tag you can add Parameters for what ever values
you want to schedule, see attached
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Tom Krowka
That will work. Not quite the way I envisioned, but close enough. Thanks.
Thomas@wkarchwk.com
www.walshkrowka.com
