‎2017-09-21 04:08 AM
‎2017-09-24 01:05 AM
‎2017-09-25 07:24 AM
‎2017-11-16 10:19 AM
‎2017-11-16 02:24 PM
‎2017-11-16 03:41 PM
‎2017-11-17 01:36 AM
Erwin wrote:
Make a schedule, specify criteria to get to what result you expect, get information. If you need some basic information on the fly, there is Element Information palette. At the level of building materials it is quite fast to get quantities, provided your model is reasonably decent.
The struggle is to link costs to quantity without going back to the system of lists as described by Godi. That takes quite some time to setup.
For our projects we use a spreadsheet for cost calculation and I use schedules to get quantities for certain things. Some things I don't model (trim mostly) and I just calculate that with the numbers I've put in the spreadsheet for the most part. Depending on the size of the project I ussually have a cost calculation done in a day or two. These are quite detailed though. Initial estimates we just go for gross volume multiplied by expected level of luxury.
‎2019-07-14 11:06 AM
‎2019-07-14 04:50 PM
