Eli Chiasson
MEP Modeler, hotlink routing
When I Start Routing on a pipe that exists in a Hotlinked file, Archicad will not pick up on the existing pipe's settings (diameter, system, elevation, etc.).
When I Start Routing on a pipe that exists in the file I am working in, this behaves as expected.
I'm modelling multi-unit residential and my workflow is to model the fixtures with initial piping, then hotlink this into another file with all the units to complete the unit plumbing. It would be very helpful if I could continue routing based on the piping that exists in the hotlink.
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
AC19-23 USA+MEP • i7-7700 3.6GHz | 32GB RAM • Windows 10 Professional
3 Replies 3
Katalin Borszeki
Hi, this is an error on our end and have been recorded in the development database as such. Thanks for letting us know about it!!
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
gpowless
While you are at it can you look into the reason that angle pipes disappear in 2d? (They are still present in 3D)
Intel [email protected] 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
Eli Chiasson
Thank you very much Katalin. This will improve our workflow for sure.
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
