‎2025-01-21 10:30 AM
Hi all.
I am trying to create an automatic mesh from a DWG file.
The DWG have contour lines with Z Values to each node/point on the lines. Is there anyway to create a mesh from these files?
‎2025-01-21 10:35 AM
You need the X, Y & Z co-ordinates, which I believe you can get from the DWG file (not that I have tried, but I recall reading about it in another post).
You can then use the option to 'Place mesh from surveys data' to create a mesh from the text file containing the co-ordinates.
But the mesh will not automatically generate contour lines.
‎2025-01-21
10:40 AM
‎2025-01-23
03:08 PM
Hi Barry.
That's exactly what I'm looking for... How to create the .txt or .xyz files from the autocad file...
‎2025-01-21 02:04 PM
There is a way to create points from lines in Autocad, but it's the same manual input you would need from Archicad...
You have to select each line seperately and do a point exercise. I couldn't find a way to select all the lines and create points on all at the same time.
‎2025-01-21 02:07 PM
If you can make it into a dxf file first, this online converter should work (haven't tried it).
https://imagetostl.com/convert/file/dxf/to/xyz
Alternatively, there's also this app:
https://www.guthcad.com/dxf2xyz.htm
‎2025-01-22 01:35 AM
I thought there was some way to read the XYZ info from the DWG.
I could be wrong, it is not something I have ever had to do.
‎2025-01-22 02:49 AM
Here is a thread regarding an Autolisp that converts lines to points, and here is one about xyz files.
‎2025-01-22 03:52 AM
If the DWG contains 3D information, it can be opened as an object ...
I think this is the post I was thinking of where you can then open the script for that object and then extract the XYZ information.
As I said, I have never done this.
https://community.graphisoft.com/t5/Modeling/From-DWG-to-MESH-a-trick/m-p/167437?p=183356
