When I say "All hell breaks loose".....here's what I mean.
1. the 2d floor plan data is not looking the same as the model I see in the 3d window.
2. We need to have the database as a full working PLN (with objects like walls, doors, windows, etc..) working for us since we will be using the database into our existing condition drawings but will need to be manipulating the existing data as well as adding on our own walls to it.
The Existing Condition Surveyors sent us a PDF file and it looks nothing like what the IFC is suppose to look like.
Walls are in different story settings which don't show up properly where they should be showing up.
custom revit objects like some detail work above the doors end up looking like "meshes".
some walls have editable properties, some don't.
some walls you can see properly, some you can't.
I mean...it really is a mess.
When I'm staring at the PLN file, and I'm looking at say the "first floor" story on the project tab, and I place either an elevation or section marker and I go to "open source view".....the system locks up and crashes...every single time.
it's as if as though Archicad has no way of calculating what the elevation or section looks like so it decides to hang and crash.
We wrote in our contract to have our subs provide us with a fully working USABLE file when we import it into archicad....and so far, it's not happening.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
