2022-11-07
10:17 PM
- last edited
a week ago
Aruzhan Ilaikova
I am having problems exporting from Archicad 26 (latest version fully updated) to sketchup (latest version fully update).
The file crashes sketchup on opening. I have tried to export files with small simple geometry, and I have the same issue.
I can export to Sketchup 8.0 format which does everything I need, but I am wondering if anybody is having the same issue.
Thank you in advance.
2023-04-13 05:16 AM
I am finally operational, and unfortunately, I have no idea what was causing the problem. Here's what I did: Uninstalled AC, deleted ModelPort, downloaded and installed AC, downloaded and installed Goodies. To test at this point: Launched AC with a default template file, created a few walls in plan view, switched to 3D window, chose Save As…, and Sketchup file type was available.
2023-04-13 05:55 AM
It might be related to a known issue with goodies and Archicad 26.
If you run 26 before you install the goodies, it will remove all of the unused commands from the menus.
Seems it might also remove the save as file type as well.
Installing the goodies after you have started 26 will not create the menus or add the save as file type it seems.
So as you have discovered, you must re-install 26 - do not start it.
Install the goodies.
Apply the latest hotfix.
Now start 26.
2023-04-13 06:15 AM
