Schedule on Multiple Layouts - 2 columns on each??
I swear I thought I'd solved this before - but when splitting a door schedule into multiple layouts, is there a way to get 2 columns of that schedule on the same layout, so it's split between 5 sheets rather than 10? I've modified it to be less than half the width of the available layout space so I could get 2 columns on each layout, but can't restructure the schedule to display as such. Please help!
4 Replies 4
I haven't tried it in a while but I believe it is still the same as in older versions.
The only way I have managed to do it is to restructure the schedule to fit the width of the page.
It will be too long so duplicate it onto another layout page.
Now crop the bottom off the first page.
Crop off the second page the part that you can see on the first page and reposition it.
If it is still too long copy to a third page and crop again.
Here is an old post explaining it.
http://archicad-talk.graphisoft.com/viewtopic.php?p=217578
And this one shows the difference between splitting and restructuring.
http://archicad-talk.graphisoft.com/viewtopic.php?p=208600
There is another post somewhere where I show the cropping and masking but I can't seem to find it at the moment.
That's what I've done for now, but you lose the "automatic" layouting of the schedule, fitting it onto layouts, etc. Just like with EVERYTHING else in this program, if you don't do it the (unintelligent) way AC wants you to, it's all customized.
NCornia
I have taken note of this post and will put it to the product team's attention.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thanks Nicholas.
