ā2008-06-13 05:59 PM
ā2008-06-14 01:55 AM
ā2008-06-14 01:31 PM
ā2008-06-16 01:30 AM
TomWaltz wrote:That may have been the original intention, and for simple labelling there may be some benefits, but there are some very powerful reasons why labels should be used as a way of tagging additional data to an object/ element:
I think the idea of scheduling labels is a little work-around-ish.
We'd be better off if we could have:
1) better ability to assign new information/parameters to elements
2) better ability to label those new parameters.
A label was intended to show information about what it's calling out, not assign new information to them (even though right now that's just about our only option short of writing add-ons)
ā2008-06-20 01:48 AM
ā2008-06-21 10:31 AM
For the purposes of creating schedules of plumbing fittings, plumbing fixtures, and equipment, simple 2d markers can be saved as their respective object subtype then added to schedules. Giving the makers a subtype gives you all the standard listing variables you need for your schedules. This is the same principle as using labels just simpler. Use the object ID as the schedule number (can be used for incremental labeling). Using a object vs label due to a situation like labeling a faucet and a sink would be difficult as they are likely in the same objectthis is nice but whole system has the Achilles' heel - objects placed on plans only will be listed. so anything you have placed in IE or details is ignored. I like the idea of label scheduling.
That may have been the original intention, and for simple labelling there may be some benefits, but there are some very powerful reasons why labels should be used as a way of tagging additional data to an object/ element:Bingo!!! mate. it sounds to me like a deja vu, more here:
ā2008-06-21 07:20 PM
Rob wrote:Hey Rob thanks for the links, a corner of the forum I have missed, you have another vote!
ā2008-06-22 02:47 AM
My work around is to bypass the scheduling and to script labels which do thissame here. I am quite glad to see that someone else has the same line of thinking which reassures me it is a good way to go perhaps. What I can say is that GS knows about this possibility, however the implementation timing or even decision to implement it in AC is big unknown at the moment, unfortunately.
ā2008-06-22 06:41 PM
ā2008-06-22 06:58 PM
Richard wrote:Again, why not give the elements themselves these abilities and just have the labels display the information?
1. A label can automatically filter any object/ element to calculate additional contextual data. (eg identify certain wall types in relation to certain zones)
2. Because labels have their own scripts, any object/ element can be tagged with more intelligent data than assigning additional parameters within the object.
3. Different types of labels can be applied to objects at the users discretion whereas additional parameters within an object would have to be assigned manually and individually.
