Show "sq ft" on zone schedule
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-09-26 06:58 PM
‎2019-09-26
06:58 PM
Labels:
- Labels:
Data management
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-26 08:52 PM
‎2019-09-26
08:52 PM
AFAIK -- The short answer is NO.
This is because Archicad does not have a property which displays working units and you can not combine two properties in a single cell. You could add a custom text column next to it and fill it in manually.
OR-- You could create a expression which converts the area to a string and append the working unit onto that string. Then use that expression in the schedule cell. Only have to do it once.
I have basically the same problem in handling currency which Archicad does not handle at all.
If there is a better solution, I like to know it as this problem comes up a lot.
Gerry
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-30 05:31 AM
‎2019-09-30
05:31 AM
You can create an Expression-based Property, which displays the Zone Area plus it adds " sq ft" to its end, then Schedule that Property instead of the Zone Area.
