Skp Export, No Result
Guru
Hi all,
On several occasions when I attempt to export a model to .skp no file is produced at the end. It will spend like 20min exporting to produce nothing...
Sometimes ignoring objects during the export works, other times not...
Thanks,
Ling
I have had a similar problem myself.
It is sometimes caused because of bad geometry in the model. These are the errors you find in the Report or it keeps on popping up everytime you move around in the model. One fix is to try finding the bad geometry and fixing it.
Do you have any geometry that you have imported from Rhino or Sketchup?
alemanda
Sometime it is due to complex geometries ... consider that even 50 doors could be a "complex" geometry.
Try to exclude doors and windows from the 3D view to be exported and check if the doors/windows are the cause of the issue
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
