2019-08-02 08:10 PM
Solved! Go to Solution.
2019-08-11 09:19 PM
another Moderator
2019-08-03 01:40 PM
2019-08-06 06:27 AM
LaszloNagy wrote:.
In ARCHICAD 23, Building Material will have Properties just like elements can have Properties.
You will be able to define Properties in the Property Manager and make them available to "Material" Classifications. Then these Materials will be displayed in the Building Material Dialog.
Hopefully, this will achieve what you are trying to do.
But, only from AC23 on.
2019-08-06 05:14 PM
2019-08-06 10:17 PM
2019-08-10 08:55 PM
2019-08-10 11:59 PM
DBS wrote:Nope, You just create a new Surface and override the one for the Building Material in the object.
…What if I want to change the color as I'm modeling? Do I need to create a new surface AND a new building material? –
another Moderator
2019-08-11 12:39 AM
ejrolon wrote:If I do a surface override, I can't get data associated with the overridden surface to schedule. Important things like color, finish, supplier, etc (see the attached screenshot as an example). How would one create this schedule using Archicad?
2019-08-11 01:10 AM
2019-08-11 06:20 AM
