2023-07-11 10:17 AM
Hi all,
We're begining to receive almost weekly an updated IFC model the construction. For us it is very useful to import their model in ours and use only the structural steel elements - columns, beams, trusses etc., while filtering everything else e.g. slabs.
The engineers are using Revit and they have multiple reference levels most of which do not match with the floor levels in archicad.
The solution so far has been by importing the IFC into a Helping file story levels that match our main project, deleting all unnecessary elements, then adjusting the Home story and Dispaly Options of most steel elements so they are displayed correctly. After that I link the Helping file as module in the main model.
This works good, but since it has to be done every time we get an update it becomes a time sinkhole.
How can I improve on this process?
Thank you and kind regards!
2023-07-18 11:22 AM
^bump
2023-07-18 01:03 PM
When you import the IFC file, do you use the Model Filter in the IFC Translator to bring in only elements you need? That way, you don't need to delete them as they are not even brought in to begin with.
Also, check the Help files for the functionality of the
File > Interoperability > IFC > Update with IFC Model menu command:
It may do what you want when you get a new updated IFC file.
2023-07-18 04:24 PM
Hi Laszlo,
Thanks for the answer. Biggest issue so far is that the Revit models have completely different levels and I do have to adjust them so the different beams/columns are shown correctly.
So far I haven't used the Update with IFC model command, because when I tried it it overwrote the home stories I've set.
