‎2015-02-17 02:50 PM
‎2015-02-17 09:30 PM
Gerco wrote:First of all, make sure that your Linear Dimension Settings are properly set because that is what is going to be used in these Dimensions.
As you can see in the attachment the View from Opening Side has dimensions by default and View from Reveal Side hasn't. How can I show the dimensions with View from Reveal Side?
How can I add a coverpage to the door and window schedulebook (A4)?You should create it as a separate page (for example in a Worksheet Viewpoint), then place it on a Layout (Or you can compose it directly on an empty Layout). Place that Layout before the Schedulebook's Layout(s) in the Layout Book so when you create a Publisher Set from them it will be easy to create a Publisher Set that contains both the Cover Page Layout and the Schedule Layouts and publish them into a single PDF.
‎2015-02-18 11:57 AM
‎2015-02-18 12:59 PM
‎2015-02-18 06:41 PM
Gerco wrote:No, when you check that checkbox, what you see as a result is the maximum that can be achieved automatically. All other additional dimensions you will need to create manually for each cell in the Schedule.
Thank you!
I'm able to show the width and height.
But can I do it also like the attachment?
‎2015-02-19 10:23 AM
‎2015-02-21 05:33 PM
‎2015-02-23 01:47 PM
