When hiding window layer in exported dwg...walls get wrong
Mats_Knutsson
Mentor
In a dwg exported where door and windows are exported in separate layers. When I open the dwg filen in acad and hide the window layer the wall misses the lines that are supposed to close th eempty window hole...see attached image.
I hope someone could help me with this little gem.
Best regards,
Mats
AC 25 SWE Full
I think this is how it is saved.
In Autocad these are just lines, no intelligence that the Wall should heal itself if the Window is removed.
Djordje
That's AutoCAD for you ...
Enjoy!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Autodask is full of surprise!
Fun always garantied!
