When updating zones (Design > Update Zones), make sure 'keep zone stamp position if updated' is ticked, or it will try to shift to the 'middle' or something close I believe.
I do not know of a way to mass shift the stamps, however I generally try to keep the hotspot that determines from where the zone should find it's boundary close to the stamp. This allows you to move the whole zone (select multiple) and update them.
Still not as handy as moving the stamps with allign command, but it might speed things up a little bit for you now.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
