apple - yosemite - multiple spaces, windows, displays
has anybody found a app or workaround, THAT WORKS
to maintain your windows across multiple spaces, when switching between 1 or 2 monitors.
it's 2016 and im trying to get organised.
my current setup (at work) is 1 mbp and a 27 inch ext display, usually work with a plan view on 1 screen and 3d on the other. Using multiple spaces, each display is configured to use the 1 space.
i've been using the app Stay with not much success. Also I know that you can dedicate an app to a specific space. But nothing i've found seems to maintain all my spaces in sequential order, be it 1 display or 2. It always groups app windows into 1 space.
Eduardo Rolon
Did you try https://manytricks.com/moom/ ?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
yes, but it doesn't seem to fit the purpose either
