2018-02-22 09:31 PM
2018-03-10 07:00 AM
2018-03-10 08:42 AM
2018-03-10 11:36 PM
KeesW wrote:Not at all – in fact, we've just rewritten a significant amount of the engine to improve the product. But it targets the NZ building code, so it's not available outside of New Zealand.
Please check with CadImage - I thought that they had discontinued their Bracing tool.
2018-03-11 05:56 AM
2018-03-12 09:57 AM
Rogerdodge wrote:You can ask, but I'm not supposed to say
Hi Ralph, may I ask when we can expect this?
2018-03-13 06:15 AM
2022-06-13 11:50 PM
Hi
I am trying to use the cadimage brace tool for a relatively simple design, after selecting walls i need braced and entering the bracing settings via calculate bracing, I note all the building dimensions and cladding weights details are greyed out. If i enter ok to see what it does i get the message
" No exterior walls selected, i.e having a composite starting with 'Ext'
All walls selected are in fact the default composite structure EXT: Stud 90
Not to sure whats going on here but any help would be really appreciated
2022-06-13 11:53 PM
Hi Ralph Wessel
I am getting the same problem
Could you please assist me
2022-06-14 01:29 AM
Assuming you are using the tool in NZ, I would caution any reliance on it. While the tool can place braces and do the calculations it is not a compliance pathway and there are multiple additional factors that need to be taken into account to create a compliant bracing configuration. Personally I stopped using the tool a long time ago when I understood its shortcomings.
2022-06-14 02:00 AM
Thanks for the reply
But I am not getting the calculation table .I think better I could have stopped to use it
