dwg translation
Hello!
I need some help on translation from AC to Autocad.
I have two plans in AC and I transform then easly to dwg but here is my problem. Ac generates each plan as dwg file but I want then in Autocad in one file. So I open first plan - no problem then I open second plan - no problem but when I copy second plan and want to paste in first plan it is impossible.Acad ignore my command ?
Help
I do not know the configuration of each of the AC files, but this sounds like you should do a File>Merge>. Open one of the AC files and merge the other in. Then save as DWG.
Or in AutoCAD you could insert one into the other as a block, then explode the block if you wish.
