We value your input!
files from rhino to ARCHICAD 14 64BIT
Is there a way to import files from rhino to archicad 14 64bit? or from sketchup to archicad 14 64bit??
5 REPLIES 5
Eduardo Rolon
Yes, as 3DS. Though they will be dumb objects, non editable. You need to Download the 3DSIn pluging for AC which you can find under the help menu.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
IFC is also an option. There's some samples and examples on my blog, http://geometrygym.blogspot.com
I'm happy to assist and advise if you wish to try.
how can i export ifc from rhino to archicad. Where is the plugin?
thank you!
archicad unfortunately is ages behind the competition!!! data exchange file formats are so lacking and make the cooperation with other software almost impossile!!!
Eduardo Rolon
Archicad can import DWG, DXF, 3DS, IFC.
Rhino can export in DWG, DXF, 3DS, OBJ.
These have been the standard exchange formats for the last 20 years.
What is AC missing?
AC27 US/INT -> AC08
another Moderator
Installation instructions for the Geometry Gym Grasshopper and Rhino plugins to exchange IFC are here:
http://www.grasshopper3d.com/group/geometrygym/forum/topics/installing-geometry-gym
I've been testing this more closely with exporting a model to AC and for some reason we have had to use R12 to import and then save the model to use in release 14. The file opens fine in viewers and tekla, I'll be posting a sample of it to the forum shortly.
Jon
