‎2018-09-27 02:15 PM
‎2018-09-27 05:16 PM
felcunha wrote:I have saved like u said and imported (External Content/ Place Hotlink)...
You're right... one solution can be to export your wall as IFC. Choose Exact Geometry Export (Precise BREP) as translator, then reimport it to your file and (if necessary) convert the object imported to morph. You'll be able to select its individual parts.
‎2018-09-27 05:52 PM
‎2018-09-27 06:24 PM
felcunha wrote:Ok, but why archicad changed the main material to water... lol
1 - Uncheck the "Merge Uniform Items" box in your schedule
2 - Open the Selection Settings for each morph, uncheck "Override surface" and change the material from water to the one you want.
‎2018-09-28 03:45 AM
‎2018-09-28 03:56 AM
Barry wrote:Sad
It is not possible to show the individual skins of a composite wall.
With 'Partial Structure Display' you can show 'Entire Model' (Core, Other and Finish skins), 'Without Finishes' (Core and Other skins) or 'Core Only' (Core skins).
It is not possible to show just the finishes or other skins on their own.
Converting the walls to a morph defeats the purpose because they will no longer be walls and will make it very hard to manipulate your model.
So if you want to see the individual skins in 3D then you will have to model them as individual walls.
But that will also make it very hard to manipulate your model.
‎2018-09-28 04:03 AM
junim2307 wrote:
Isn't possible to create another entire model?
‎2018-09-28 04:05 AM
Barry wrote:Well, there has core only, and 2 other options
I don't understand.
How would another model help? - you will still have the same problem.
‎2018-09-28 04:16 AM
junim2307 wrote:3 others if you include the Core of Load Bearing Elements - very similar to core only - still can't show the finishes and other.
