isolate 3d skin to show the map quantity
Hello guys,
I'm making a schedule of skin walls, same as the image below.
so... for example... I need to show just the "Plaster Gypsum External" quantity in 3D, so I click on element line and then "Select in 3D" option right?
and appears this:
my doubt is...
Is there a way to isolate only "Plaster Gypsum External" like the image below that shows the exact 4,18 Area?
I tryed Entire Model Option but I don't know how to isolate skin by skin... it worked for "Core Only" but not for skin by skin
17 REPLIES 17
felcunha wrote:
You're right... one solution can be to export your wall as IFC. Choose Exact Geometry Export (Precise BREP) as translator, then reimport it to your file and (if necessary) convert the object imported to morph. You'll be able to select its individual parts.
I have saved like u said and imported (External Content/ Place Hotlink)...
In this time, the schedule messed up...
I tryed to break hotlink (Embend Elements) to convert to morph (worked to separate skins) and still didn't work for quantity... all the 3 skins changed to "Water" and still don't appear area values, lol...
any idea?
felcunha
1 - Uncheck the "Merge Uniform Items" box in your schedule
2 - Open the Selection Settings for each morph, uncheck "Override surface" and change the material from water to the one you want.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Ok, but why archicad changed the main material to water... lol
To change this manually will be almost the same that create wall by wall to each skin like I'm doing currently
It is not possible to show the individual skins of a composite wall.
With 'Partial Structure Display' you can show 'Entire Model' (Core, Other and Finish skins), 'Without Finishes' (Core and Other skins) or 'Core Only' (Core skins).
It is not possible to show just the finishes or other skins on their own.
Converting the walls to a morph defeats the purpose because they will no longer be walls and will make it very hard to manipulate your model.
So if you want to see the individual skins in 3D then you will have to model them as individual walls.
But that will also make it very hard to manipulate your model.
Sad
would be so good if the archicad had this option
Isn't possible to create another entire model?
I don't understand.
How would another model help? - you will still have the same problem.
Barry wrote:
I don't understand.
Well, there has core only, and 2 other options
If possible, It could create for example internal skin and external skin and set in composite wall
3 others if you include the Core of Load Bearing Elements - very similar to core only - still can't show the finishes and other.
Add your vote here for more Partial Display options.
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=49055&p=242070&hilit=Partial+Structure+Dis...
