‎2009-01-13 01:05 PM
‎2009-12-07 07:12 PM
‎2010-02-18 06:29 PM
‎2010-02-18 11:32 PM
Coty82 wrote:
Hello, I know its an old topic but i am having the same problems here. And i use AC13 and C4D 11.5. THe Exchange plugin triangulates the models wich is a shame. On the opposite, the 3DS import plugin has the "force smooth" options and it works great but does`nt have the cutplane sensitivity. What can we do to have the best from those 2 plugins?
Did anybody wrote to Graphisoft about the future realse of the C4D exchange plugin? I am sure this improvement is very easy to do.
‎2010-02-19 09:17 AM
mikoaj wrote:Thanks Mikoaj for your advice. Can you be more specific? I have imported an organic model with 3ds in plugin and in cross-section the fill cut surfaces doesn`t work. Only the cutlines are detectable.
You can use 3ds for cross-section and obj from c4d plugin for floor- cut plane (next explode geometry to lines and MANUALY (DAMNNNN this can be painful) earse the triangulation)
The other solution is switch to Rhino! curently on Mac is open via invitations WIP wersion ---> which has beautiful working commnad MAKE2d
KissXOXO
‎2010-10-03 04:28 PM
‎2010-10-06 03:59 PM
‎2010-10-11 05:49 PM
