switch 32 bit to 64 bit, what is invovled, anyone done this
Erika Epstein
I've been thinking of switching my windows XP from 32bit to 64 bit to get more from archicad. Has anyone done this and could share their experience, outline what is involved re other programs etc.?
On the few occasions over many years that I've reinstalled the OS and installed all new software its been days of effort.
Other than Archicad and Microsoft Office, do other programs have this choice or does one have to repurchase/pay some kind of upgrade type fee?
Would I be better if this machine can do it switching to Vista or 7?
Thanks in advance
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
13 REPLIES 13
A few questions first:
1)Why do you want to switch from 32-bit to 64-bit?
Most people tend to switch because 64-bit OS do not have the 4GB Memory or RAM limitation that 32-bit OS have. So that way they can get as much RAM as they wish (8GB, 16GB or higher) and not be limited by how much Windows will limit or take advantage of. Additionally, 32-Bit Windows versions (both XP and Vista) don't really give you all 4GB of RAM even when you do have it, as about half of it is reserved for windows processes; so technically even with 4GB RAM you only have around 2GB or so available for your programs to use. But there's a work-around to this; more on that in a bit.
However, all this, (switching from 32Bit to 64Bit, and getting more RAM) only matters if the actual programs you plan on using will take advantage of more than 4GB of RAM, i.e are 64-Bit programs. 32-Bit programs cannot see more than 4GB (or what''s left over from Windows) of memory available, and so don't ever take advantage of it. So even using a 32Bit program in a 64bit OS is kind of pointless from the perspective of having more than 4GB of memory since the program will not take advantage of anything above the 4GB.
2) In the event that you don't plan on getting more than 4G of memory, have you considered getting a 4Gig switch for 32bit Windows?
Basically this will save you the trouble of re-installing OS's, and allow your programs to take advantage of pretty much all the memory you have even in a 32Bit environment. It's a component that circumvents 32Bit Windows' 2Gig memory limitation, and releases most of it to the programs available.
The reason I ask these questions has also to do with the fact that ArchiCAD (as of right now anyway - and which I assume is one of the reasons for a switch), is still a 32Bit application, and so would never gain you any advantage in switching from an 32Bit to 64Bit OS. In other words, it's not going to use more than 4GB of memory even in a 64Bit OS environment, and so if this is a primary reason for a switch, then as far as AC is concerned, it's kind of pointless, atm.
You might have noticed people have been begging Graphisoft to migrate ArchiCAD to a 64 Bit platform or at least allow for both options and frankly speaking, for a mult-core aware application like AC12, it's kind of retarded that it's still just a 32Bit app, even when Microsoft themselves have stated that they will be abandoning the 32Bit platform, and 32bit Windows in a couple of years; and more importantly even when most of their users are already migrating to 64Bit Windows, and getting more memory for their applications that are 64Bit - (including non-multicore aware competitor Revit, which is available in both 32bit and 64bit
versions).
Further to which, there are also other advantages of using a 64bit application in a 64Bit OS, beyond just the memory since there generally more resources available to the programs, and they're not constantly fighting with Windows for stability - i.e less crashes, faster. I'm currently using 64Bit Win7, and my 64bit applications just fly and are way more stable than the 32bit versions also in the same system.
Who knows, maybe we'll get lucky with AC13.
I should warn you though, that 64Bit Windows (XP, Vista and Win7), along with switching to them, do tend to have problems - primarily to do with hardware, and drivers not supported. So here is where there may be issues in switching - be sure to check that your components have 64Bit capable drivers first, otherwise the switch may be more of a headache than a benefit.
But in terms of what you'll have to go through, you'll inevitably have to re-install all your programs, since, the directory structure for 64Bit windows is different to the 32Bit version, and I don't really think you have to pay any upgrade fee for any of your programs unless you plan on getting 64Bit versions (and assuming that they don't already offer the option when installing to install as a 64-bit application - most programs will automatically detect a 64-bit system and prompt you to install the 64-bit version; if available).
Oh, and stay away from Vista - far faaar away- especially, if you have the option. Even though 64bit Vista is still more stable than the 32Bit version, I would still advise going with either 64bit Windows XP or preferably 64Bit Windows 7 (my choice). Vista is the reason Microsoft are so anxious to release Windows 7 as soon as they most possibly can.
Again, I repeat, 64Bit OS is NOT going to gain you any advantage (memory-wise, resource-wise) from ArchiCAD that you wouldn't already have with using ArchiCAD in a similar 32bit OS with a 4gig switch. Other programs (64Bit ones) may, but definitely not AC. So weigh that against any potential decision to upgrade and re-install everything all over again, along with all the hassle that comes along with it. ArchiCAD is not a 64-bit application, and unfortunately them's the breaks, until GS decides otherwise.
I just noticed that you're on a Mac (MacPro maybe?) with OS10.5, which might suggest that you're having to use Windows through Parallels or Bootcamp perhaps?
That could also complicate things a little further since, as far as I remember, either one or both of those also limit the amount of resources available to to Windows, than are available to the Mac side. Despite the fact that Windows, as I've heard, runs much better on a Mac system than it does on a PC.
I do recall a friend of mine who was an a MacPro but was primarily running Windows on it, and his system was just a monster with everything blazing fast and smooth. He did have 8 cores and something like 20Gigs of Ram, and he was also pretty much exclusively running 64bit applications; so that may have had something to do with it, as well.
But I also recall that he also did have a lot of issue with drivers and programs simply not starting up or working correctly.
Erika Epstein
Wow what a great set of answers.
Yes, I was wanting to get more with AC than I do currently and thought 64 bit might be the way to go and that brought up the XP/Vista/7 quandary.
Thanks Bricklyne
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
Oops, just saw your second post. My desktop is a Dell XP SP3. When I replaced the desktop, at the beginning of last year I chickened out on the mac.
At the end of last year I needed to replace my laptop. I did with the mbp and haven't looked back. I've never even got round to installing a virtual pc, haven't needed it in the offices I work with.
I expect next time I replace the desktop it will also be with a mac. In the meantime, I have hit the ceiling with archicad a few times on it and was looking ahead to what I might do to improve this machine. I'll wait and see about 13 and check my other applications as well.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
KeesW
Erika
We are running AC12 on Vista 64. Please check my postings for some further comments.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Going forward with your system, if you plan any upgrades, then yes move on to a 64bit OS. Mac OSX 10.4 and above is mostly 64 bit, and I believe with the new Snow Leopard (10.6) release that all of the core bits will be 64 bit. As far as to Windows, don't bother with XP 64bit. It is not very well supported by hardware folks. I would go to Vista 64bit or, even better; stick around a bit for the release of Windows7. It should be released to commercial stores by October 22nd of this year. It is a good bit less resource hungry than Vista, and plays nicely with less heavy-powered machines. In many test cases the speed is on par or better than XP is.
I will echo a number of the thoughts from Bricklyne Clarence above, that even if your OS is 64bit, if your application is only 32bit, you can't easily break that 4GB barrier. So if you do have 4GB or more of RAM, then you should have already upgraded. If you don't have 4GB or more, then it isn't pressing that you do so. Also, moving to a newer OS, 64bit or not, you need to check on if drivers are available for your gear. Most hardware manufacturers have gotten on board since Vista came into being, and the major ones (Intel, AMD/ATI, Nvidia, etc) are already in there for the Windows 7 Release Candidate.
If you want to play around with Windows 7 in bootcamp or parallels on you MBP, the current release candidate is free to download and try, but the license on it expires come June of 2010 (and it functionally ends on March of 2010). However that gives you a good deal of time to see if you like it or not. The links to download it (on Microsoft’s site) are at:
http://tinyurl.com/9agzvs
Erika Epstein
Thanks Data,
I've held of upgrading for the time being. I've started looking into what it will mean for all of my programs to upgrade.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Hello
Problem switching from 32 to 64 is all the printer driver. Many printers driver doesn't exist for 64.
henrypootel
Make the switch to x64 now.
That way, you'll be ready as soon as a 64-Bit version is released.
Why would you want to be content with 32 bits less than others anyway?
64 is twice the size of 32(at least) so it must be good right?
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
