2024 Technology Preview Program
tag lists property data type...what for?
Mats_Knutsson
I can see how it works but what is the IRL use for the data type Tags list in properties? /Mats
AC 25 SWE Full
poco2013
Mentor
From Help!
•Tags List: Can be a tag or series of tags (e.g. Building A, Floor 2, Common Use, Kitchenette)
–This data type cannot be used for an Expression-based property.
Tags List is nothing more than a delimited value string. I can only speculate that it was intended to be used in expressions in conjunction with the SPLIT command but was deleted in favor of OPTIONS. In that context, Its usage would then allow the designer to select from a pre-assigned fixed list of options rather than rely on the OPTIONS data type which only gives the value selected by the user. Same thing can be accomplish just by using a comma delimited string but not as easy to configure.
IOW - six verses half-dozen which I guess is why it was not used in expressions.
Gerry
Mats_Knutsson
poco2013 wrote:
From Help!
I'll forget about the tag lists as of now . We're not using 22 yet and I'm not sure we will push it internally but keen refining 21 until 23 comes out. During this period I might have a dream that will clarify the business value with tag lists .
AC 25 SWE Full
