Browse
Graphisoft Community
All
This category
This board
Articles
Users
Products
Design
Design articles
Design forum
Document & Visualize
Document articles
Visualize articles
Document & Visualize forum
Collaborate
Teamwork articles
Data Exchange articles
Project Management articles
Collaborate forum
Setup & License
Let's get started!
Setup & License articles
Setup & License forum
Get Together
What's new?
Wishes forum
Developer forum
Graphisoft User Group
Graphisoft Insights
Challenges
My Graphi Story
One Override to Rule Them All
Snow Globe Challenge
Português (Brasil)
日本
International
search
Help
All
This category
This board
Articles
Users
Products
Design forum
Graphisoft Community (INT)
Design
Design forum
Re: AC18 - Stretching a custom profile "down"? not
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Pin this post for me
Bookmark
Subscribe to Topic
Mute
Printer Friendly Page
AC18 - Stretching a custom profile "down"? not happening?
rob2218
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Email to a Friend
Report Inappropriate Content
2016-08-01
01:51 PM
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Labels:
Labels:
Archicad
Design
All forum topics
Previous Topic
Next Topic
2
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Email to a Friend
2016-08-01
02:14 PM
You can't make it shorter than the original profile. So start with the minimum height you will need, and then you can stretch it out from there.
rob2218
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Email to a Friend
2016-08-01
02:16 PM
makes sense...thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Post Reply
Didn't find the answer? Start a new discussion
Create new topic
Related articles
Railing Tool Sequence Mirrored After Software Upgrade
in
Design forum
solid element operations
in
Design forum
Setting a building Material to a Complex Profile Column
in
Design forum
Railing Fundamental Error
in
Design forum
AC25 running under Apple Silicon
in
Design forum
Labels
24
1
25
5
26
1
2D
2
3d
1
3D Reference Model
1
3D view
1
7050.0
1
AC24
1
AC25
3
AC26
9
Accessories in AC26
1
accessory goodie
1
Ad
3
Add-on
1
Algorithmic Design
1
alter
1
angles
1
apartment design workflow
1
Archicad
18,655
Archicad 26
1
Archive
1
array
1
AutoCAD 3D
1
Automation
1
Beam
2
beam tool
1
BIM management
2
BIM MEP
1
BIMcloud
1
BIMcloud Basic
1
Brick
1
bug
10
building material
1
Building Materials
1
C++
1
cabinet
1
cabinet panel
1
Cabinets
1
clean up
1
cleanup
1
Collaboration
1
colors
1
Column
2
competency
1
Complex profile wall
2
Complex Profiles
7
composite
4
composite walls
1
Connection
1
connectons
1
Construction wishes
1
corner
2
crash
3
curbs
1
Curtain Walls
8
Curved Stair
1
custom
1
Custom Door
1
custom door leaf
1
custom door panel
1
custom leaf
1
Custom Window
1
cutting plane
1
d
1
defaults
1
Design
17,327
detailing
1
Door panel
1
Doors
1
Doors & Windows
8
dow
1
drafting
1
Drafting wishes
1
Drawing
1
DWG
1
dynamic
1
EcoDesigner
174
Edu
473
Electrical
1
Element Transfer Settings
1
elevation
2
energy
1
error
1
File
2
Fill Origin
1
Fills
1
filter
1
finishes
1
floor
2
Floor Plan
1
folder
1
forever_bug
2
frame surface
1
Freeze
1
gap TBD
1
garage door
1
GDL
6,905
geotiff
1
graphics
2
Grasshopper
223
Hardware
1
Hi
2
hidden
1
hide
1
hide selection
2
hotkey
1
Hotlink & External Content
1
Hotlink and External Content
3
Hotspots
1
i
1
I LOVE the ability to create folders
1
Iceberg
1
IFC
3
image based objects
1
import
2
in
1
Inconsistent Functionality
1
inside
1
installation
1
Interface
1
interior elevation
1
intersection
6
issue
1
Issue Management
1
iterations
1
junction
1
Kitchen
1
ladder soffit
1
Landscaping
1
Layers
2
Layout
1
Learn
1
level
1
Library
6,898
Library (GDL)
3
Library Part Maker
1
light
2
line
1
line gap extend connect
1
lines to the morph
1
Linetype
1
Link
1
Live
1
Live Connection
1
lo
1
LPM
1
macOS
3
mahalo
1
material
1
material transfer
1
MEP
3
Mesh
1
mirror
1
module
1
Mouse
2
Move
1
multiply
1
My first attempt
1
Navigator
1
new features
3
newfeature
1
numbering
1
Object
4
Objects
5
Opening
1
options
1
Ordening
1
Origin
1
Other
3
outside
1
PARAM-O
2
parameter passthrough
1
parameter transfer
1
PDF
1
Pens
1
Performance
2
Photoshop
1
PLA
1
plan
1
Plugin
2
pocket door
1
Pointcloud
1
priority
1
profiles
2
Project Zero
1
project2
1
Property Expression
2
rail
1
Railing
2
railing panel
1
RAL
1
reinforcement
1
Rendering
1
Renovation
2
REVIT
1
Rhino
1
Rhino & Grasshopper
1
Roadmap
1
roof
4
Roofs & Shells
3
RVT
1
save
1
Save Selection As
1
Schedules
2
Section
1
sections
1
SEO
3
Setup
2
shaped
1
shortcut
1
shortcuts
1
show
1
show-hide
1
Sill
1
size
1
skin
1
Skylight
2
Slab
1
Slabs
1
sliding window
1
Snap
1
Solid body
1
solid operations
1
Stairs
1
Stairs & Railings
7
story
1
Story Settings
4
Strucutre
1
Student
479
subtraction
1
suggestion
2
surface painter
1
Surfaces
2
Sustainable architecture
175
Teamwork
2
terrain
1
Texture
2
timber
1
timber framing
1
Tips & Tricks
231
toolbars
1
tools
1
Trace Reference
1
Trial
1
trim to roof
1
Troubleshooting
1
updates
1
user input
1
variables
1
Views
2
visibility
1
Visualization
1
wall
3
Wall covering(CI tool)
1
wall intersection
1
wall openings
1
wall penetration
1
wallhole
1
Walls
3
Warning
2
window
2
Windows
4
Wishes
1
Wishlist
1
workspace
1
wrong
1
X-Ray
1
Zones
3
欧
1
Latest solutions
Distribute Tool Grayed Out Unavailable
Design forum
Rafters butting up to rafters although showing the...
Design forum
Gap in the stair
Design forum
Railing Tool Sequence Mirrored After Software Upgr...
Design forum
How do I select & deselect all layers in the layer...
Design forum
View all
Most liked posts
Subject
Likes
Surface Picker
11
Rebar & ICF accessories
9
Re: Surface Picker
6
Re: No FBX in Archicad 26
5
AC26 Edit Selection Set - Layer Selection
5
View all
Create new topic
